Old 02-06-2016, 07:02 PM   #1
Moorio's Avatar
Where is the 110 outlet
I have an 11 378 XL and want to know where the 110 power is in the bedroom? I found power in the closet for the TV
Moorio is offline   Reply With Quote
Old 02-06-2016, 07:09 PM   #2
Send a message via MSN to Tiggerdad
Look at the side of the bed frame. My Crusader has one on each side of the bed frame.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 02-06-2016, 08:07 PM   #3
Moorio's Avatar
Got it
Too lazy to bend down that far
Old 02-06-2016, 08:27 PM   #4
heavynlori's Avatar
Plug in a short extension cord and leave the other end up where you can reach it !
heavynlori is offline   Reply With Quote
Old 02-07-2016, 06:46 PM   #5
It's on the side of bed frame. One on each side
daddio is offline   Reply With Quote
Old 02-07-2016, 10:32 PM   #6
110 outlets in bedroom
We have a 2016 model and there is an outlet on each side of the bed aboutma
Foot from the nightstands.
Wesley1249 is offline   Reply With Quote
Old 02-08-2016, 06:03 AM   #7
Thumbs down TT Electrics
Why do TT Mfg. have to put electric control panels right next to the floor??? So tired of crawling around on my knees to check a fuse. How much more could 3' of wire cost??
pdqparalegal1 is offline   Reply With Quote
Old 02-09-2016, 11:28 PM   #8
It may be the wire, it more likely is the space in the wall to put the stuff in.
nothermark is offline   Reply With Quote
Old 02-10-2016, 09:38 AM   #9
kenandterry's Avatar
Not sure about your room layout, but if the control panel for the breakers and fuses were in a higher location, you'd probably complain about a drawer or closet that wasn't conveniently located. Also, the gauge of wiring for electrical circuits is determined by how long a wire run must be.
If you find yourself having to get down to check fuses and breakers that often, then I would hazard to guess you've got an electrical problem that needs further attention.
Just food for thought.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
electrical
