Old 03-04-2010, 06:34 PM   #1
JKL
Where is the waterpump hiding?
Friends bought a 2005 Georgetown 342DS.
Where is the waterpump on this motorhome? It seems to be eluding us.
Any help is appreciated.
Kevin
JKL is offline   Reply With Quote
Old 03-04-2010, 07:00 PM   #2
NWJeeper's Avatar
Kevin
Welcome to the forums.
Each model is different and it can be different from year to year. It took me a while to find mine. FR likes to hide things behind plastic blank off panels. look for things like this or panels with circular inspection disks that can be unscrewed. More than likely it will be located close to the water tank so if you can find the drains or vent hose coming from the tank start you search in that area.
Good luck.
Ed & Wendy
www.nwjeepn.com
Old 03-04-2010, 07:55 PM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Try looking in the compartment where the propane tank is. Mine is behind a black panel above it with 2 of those 4" screw in caps.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-04-2010, 08:54 PM   #4
TulsaSteve's Avatar
Mine is in the same spot as Charlies. Found mine by listening and feeling. Find a quiet time, turn the pump on and open a faucet, then listen for the motor and feel around for vibration.
TulsaSteve is offline   Reply With Quote
Old 03-06-2010, 10:22 PM   #5
JKL
Yep it was through an access portal by the propane tank - thanks for your help everyone!
Kevin
