07-26-2017, 12:45 PM
where is water tank bypass 2016 georgetown 369 XL
How do I get water to the water heater. I have a 2016 Georgetown 369XL. I cannot find the bypass valve to send water to heater. We filled tank from our residence, but there is no water in the heater. Please help, we are first time owners and are totally clueless. Thanks
07-26-2017, 12:54 PM
Assuming your water heater/tank has a door on the outside of your rig, the inside part of the heater/ tank is where you'll find the bypass. Some are in the bath others are in the rear bedroom.
07-26-2017, 12:55 PM
Look under the motor home below water heater. There should be an opening where you twist off the cover. Bypass valves are in that space.
07-26-2017, 01:01 PM
Kanadian Kamper
Have you ever had hot water working in your rig?
Ken and Terry
07-26-2017, 01:14 PM
just got 3 weeks ago... it was in winterized. We are trying to de-winterize it
07-26-2017, 01:20 PM
yes, heater tank is outside panel below the bedroom. Do I look in cabinet areas in bed/bathrooms for valves or look for a hidden panel in those areas.
07-26-2017, 01:25 PM
No
Look at underbelly of motorhome below water heater. That is where there is access to by pass valves.
07-26-2017, 01:31 PM
Kanadian Kamper
Throw a tarp on the ground under the water heater.
Crawl under, looking up. You should see a plastic circular access door near the underside of the water heater.
If you can, look up inside. Do you see 3 taps on the water Lines?
If so, and the RV came to you still winterized, turn each tap 90 degrees from the position you find them in. Don't try to analyze it as a newbie, just turn each one 90 degrees from where you find them. Two taps should be the same direction each time.
Ken and Terry
ok. got on ground and found black cap under/behind heater unit. removed cap saw 3 valves (2 blue 1 red). do I open all three?
07-26-2017, 01:32 PM
Yes, it'll be in a panel in the bedroom.
07-26-2017, 01:40 PM
Yes
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-26-2017, 01:42 PM
ok found taps/valves. Am I now ready to fill with tank with water? And it will go into the heater at the same time?
Kanadian Kamper
Turn all three 90 degrees from the position when you found them.
Two of them should be in the same position no matter time of the year.
Ken and Terry
07-26-2017, 01:44 PM
you'll have to use the electric pump.
and that will involve another valve or two
If you have an owners manual, I'm pretty sure that will help you.
Especially if it's still winterized.
07-26-2017, 01:46 PM
Kanadian Kamper
dwalk44
Where are you located?
Ken and Terry
07-26-2017, 01:53 PM
You might be better off using city water initially -- no pump involved.
If you do, open faucets to see if there's any pink liquid. If there is, open all the faucets until the water is clear.
07-26-2017, 01:54 PM
The user info says Sterling Heights, MI
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
07-26-2017, 02:04 PM
better yet, if your bought it from a local dealer or owner, ask them if they will show you.
07-26-2017, 04:40 PM
we flushed all pink out of water lines inside cabin.
07-26-2017, 04:42 PM
Very good [emoji16]
