07-30-2018, 10:29 AM
#21
In my Georgetown 31L5, x2 for dolfan1981, except I use a rectangular trash can. Both work. Just like dolfan1981 I stow it in the bin next to the water/waste-drain. In the same bin in I stow my inside and outside cleaning supplies, maintenance supplies, and tank treatment supplies.
McCormickJim
2017 GT 31L5
07-30-2018, 10:49 AM
#22
Originally Posted by jtesta1
Under the bed.
Better than to coil it around the kitchen table leg.
07-30-2018, 04:56 PM
#23
My sewer hose has caps for both ends. I just fold it in half and stuff it in the compartment where the valves are located in my 2011 Georgetown. The spare hose, the spout that gets inserted into the sewer pipe and my rubber donut are stored in a heavy duty garbage bag in the same compartment.
Additional items stored there include the toilet wand, expanding snake stand for the sewer hose, mini sandbags to hold the spout in the sewer pipe, and a box of gloves to wear when dumping. The only non sewer related item in the compartment is my collapsible windshield squeegee. The squeegee gets stored there because it's right next to the gas filler pipe.
Phil
07-30-2018, 04:58 PM
#24
Put it in a plastic tote box and store in my storage bin!
07-30-2018, 07:14 PM
#25
Sewer hose storage
I keep my sewer hose in a vinyl fence post that is large enough to accommodate the fittings on the end of the sewer hose.
It is hung above the propane tank and terminates in the compartment that houses the coach batteries and levelers.
Be certain that the post slopes away from the batteries so that water does not drip on them when storing a wet sewer hose.
07-30-2018, 09:06 PM
#26
Valterra
Originally Posted by myredracer
I installed a Valterra sewer hose carrier under our TT and love it! Unlike RV bumpers, these carriers are large enough in dia. for hoses to easily side in/out plus they will never rust. They are available in a few versions depending on where/how you want to mount it. Recommended!!
Same one I use, see post#12. Works great!
2019 Arctic Wolf 285 Fiver (Party House)
2019 Ford F150 3.5 V6 Max tow (SnowFlake)
Pixel, our Cockapoo puppy!
08-07-2018, 01:23 AM
#27
Originally Posted by Viatorem
First off: Yes, I searched the other forums here and read a zillion posts about the "fence post" mods and such. But none of them worked for me - most all were on trailers, and bumper mounted, etc. yuck.
So, I'm curious to learn/see what us Class A Georgetown motorhome owners have done for storing the sewer hose. Rather than coiled up in a bin, I'm looking for ideas for possibly stashing it under the rig - able to be easily accessed but not easily seen/noticed.
Thanks in advance!
DJ
I had a 36' 5th wheels that had two 5" plastic pipes mounted in front of the axles that held mine.
I now have a 36' Lexington and I bought a 6" X 5' piece of galvanized stove pipe with end caps and it slides in my rear storage area
08-07-2018, 11:03 AM
#28
What do you use when one end of the sewer hose had a 90 degree plastic elbow fitting attached. Seems none of the "fence post" or similar devices would allow for that 90 degree elbow.
08-07-2018, 11:46 AM
#29
Read post #24. That should work perfectly!!!
Also, you might consider stuffing the hose in a plastic lined compartment after you thoroughly rinse out the hose. Should save a wallet full of cash- hours of unnecessary installation of any/all those different types of hose keepers etc etc etc.
#30
I don't use a 90 on the end of mine but if I did, I would have purchased a 6" piece of galvanized stove pipe.
( after snapping the metal together to form the pipe I used metal foil tape on the seam. Then I screwed and taped one cap for the bottom and put a handle on the cap for easy access for the top. It a very inexpensive way to store your hose.)
08-07-2018, 05:13 PM
#31
You can cut a U shape out on the side facing down.
08-07-2018, 05:56 PM
#32
Mine fits nice and cozy right inside the rear bumper.
2018 Salem 27RKSS
2002 Chevy Silverado 1500 5.3L 4WD LBEC
U.P. Michigan
08-08-2018, 02:26 PM
#33
Originally Posted by rcampli
You may have done that to your rig, but that's a picture of my modification in my motorhome......
I am flattered however.
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
08-08-2018, 02:32 PM
#34
I rinse good and drain then put in front compartment of my Cedar Creek
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
08-08-2018, 02:39 PM
#35
A smart rv'r. When I had a TT, I stuffed the hose in the rear bumper. Don't have that in my MH so the plastic lined compartment is perfect.
08-08-2018, 05:06 PM
#36
I didn't have my own pic and had already downloaded yours to show one of my friends
08-09-2018, 04:43 PM
#37
Originally Posted by Daroyaci
I used this same concept on my 2016 364ts. Put both of them inside front drivers side compartment above propane tank. Has work out great since day 1.
Out of site, out of mind. No mess ,no fuss. Hope that helps
Great idea...
Anders Campbell River,
BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab Chuckwagon: 2020 GD Solitude 310 GK
My RV Cookbook now on Amazon! USA or Canada
Travel Blog
Cooking Blog
08-10-2018, 02:24 PM
#38
Isn't this a Georgetown motorhome thread?
We don't have rear bumper storage.
