After thinking about your post I realized you were not or probably not talking about a ford pickup "less than f-350" but yet talking about a coach. and that would be different . BUT there is an exception because medium duty and heavy duties use allison . SO WITH that being said it is possible for a ford to have an allison .
We had a 93 ford f-600 with an allison . so anythings possible .
Not talking pickup trucks but the Ford F-53 22,000 lb bare chassis.
Theres a good chance its an allison then !
only way to tell is to slide on under and look .
I believe on the right rear of the trans there should be a tag .
