Originally Posted by whoDoMan
Hello Georgetown owners. Have a 2014 377XL. Question... the coax connection at the outside port has only a single connection. Inside there is a switch box that has 3 positions 1) roof ant, 2) park cable 3) satilite. Sat is prewire to a spot on the roof to mount a perminate SAT. I want to use my tailgator on the TV when no park cable or roof ant are unavailable. Any direction on how to make it work. I'd like to hook in through the coax port on the outside of the unit maked "Park Cable" Thanks in advance.
All the answers are correct.
When I am staying at a campground for a few weeks this is what I do with my Tailgater Dish.
I place my Tailgater on roof in the rear of my Georgetown for security reasons. I'm able to lock it up to the ladder.
I use the tailgater coax and run it across the roof and enter around the rubber on the closest slide to my TV and run it directly to my VPI211k receiver box.
I use the HDMI cable output and run to my TV. With that said I only use the TV speaker system and not the surround sound system.
I also figure my coax is much better shielded than the cheap stuff in the motorhome. Having a short run helps maintain a higher voltage to run the dish. More coax and switches just adds resistance and drops voltage/signal
Now if you can't climb up on the roof then yes hook it up to the outside connector.
