Old 10-08-2014, 07:59 PM   #1
mack1roc's Avatar
Winegard traveler
Hey question and hope someone can help. I have. 2015 Georgetown 351 with a winegaurd traveler for direct tv. When I power on the traveler box it goes through the steps to start searching and then searches, but that's as far as it goes. It keeps spinning Around and Around and won't find signal. Now I know this has nothing to do with direct tv it's the winegaurd dish or box as my buddy is right next to me same setup and it signal great. I have done the obvious pull power to it resets itself, and check all the connections. Anyone have had this problem or any ideas ? The unit worked last trip which was about a month ago and the unit is only 3 months old.
"MACK"
2006 F350 6.0 Diesel 3.73 4x4 FX4 "sold"
2010 Keystone Laredo 310RE 5th wheel "sold"
2015 Georgetown 351
mack1roc is offline   Reply With Quote
Old 10-09-2014, 08:24 AM   #2
Obvious question: The dish have a clear view of the southern sky?
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 10-09-2014, 09:57 AM   #3
CAT-RN's Avatar
Winegard traveler
That's what mine does when there are trees in the way. If that is it try to move ur coach 5 ' either way.
I have moved mine as little as a foot before and picked up a signal. Just has to see a hole thru whatever is there.
Russell
CAT-RN is offline   Reply With Quote
Old 10-09-2014, 10:25 AM   #4
WDK
WDK's Avatar
My thoughts are the same...power down, move the coach, turn the receiver on for a few seconds and then the dish if they are powered separately.
WDK
WDK is offline   Reply With Quote
Old 10-09-2014, 08:11 PM   #5
mack1roc's Avatar
I am in the infield in charlotte so no obstructions. And I have powered it down over night and re-attempted in the morning. I did locate the problem. connection c on the dish went bad. I moved all the connections to a and it worked just fine. So one of my connections went bad.
"MACK"
2015 Georgetown 351
Old 10-10-2014, 06:09 PM   #6
may I add a question
I have a 2015 Georgetown 378 and cannot locate the satellite connection on the outside of the rig. I know the box inside is above the passenger seat. I have a winegard carryout g2 for direct tv, If someone can help me with the outside issue. Stopped at a dealership - no one knew. Have call in to FR, but 5 days and no response.
Thanks for any assistance,
EChambers
echambers is offline   Reply With Quote
Old 10-11-2014, 11:14 AM   #7
Senior Member - Retired
Look for a coax connection in the driver side exterior compartment containing your fresh water and sewer connections.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 10-12-2014, 12:12 AM   #8
On my 2011 378 it is located under the coach near the front right. I didn't see it but just had my coax replaced and the tech told me where it was located.
Good luck and Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
travel, winegard
