Old 08-17-2016, 07:51 AM   #1
Wineguard trav'ler satellite dish
Can anyone tell me if there is a reinforced area on the roof to install the dish on a 2015 Georgetown xl 377. If anyone has installed their own dish would you share any problems that you ran into. Thanks
revflyer is offline   Reply With Quote
Old 08-17-2016, 08:02 AM   #2
SeaDog's Avatar
With the weight of the dish there is no reason to worry about a specific area being reinforced. Placement when I installed a dish on my class A was determined by the closest I could get to the entertainment center and still be centerline on the coach. I found the job to be straight forward and not hard. Take your time and locate all wiring needed prior to cutting into the roof.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 08-17-2016, 03:23 PM   #3
abjb's Avatar
You're probably already pre wired for a dish, look for a plumbing type vent on the roof above the cabinet where your coaxes, AB switch and DVD player are.
Post #7 in this thread has a picture of the vent and some good info..
TV feed wiring diagram
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is online now   Reply With Quote
Old 08-21-2016, 05:35 PM   #4
borba's Avatar
revflyer hi I had to do all new coax and power wire the ones fr install to short and did new hole no problems with water liquid over a year ago my rig is a 2015 378x
frank
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
satellite
