09-17-2011, 07:49 AM
Winter Use of 2011 378TS
We will be using our 378TS this winter in the very cold and know about the "artic pack" which is heat pads. Does anyone know if the coach heat has a duct into the water tank, holding tanks compartment area for heated holding tanks? Our last unit (not a Forest River) did and it kept the tanks and water lines from freezing down to Zero degrees.
It strikes me that it should as the heat pads do nothing to protect the water lines. I asked my dealer and as usual he didn't know and did not seem inclined to ask the factory.
Any information on this would be appreciated.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
09-17-2011, 09:05 AM
A line slideouts
There should be a 1 1/2 duct there to blow heat on the holding tank! Any other questions just let me no I work at forest river building these coaches. I must point out though the thermostat running the heat through there is located in the bedroom and will only turn on when its cool enough in the bedroom. I will half to check and get back to you but I think there is a heat pad on all tanks to keep them from freezing!?
09-17-2011, 09:31 AM
Thanks for the quick response, and yes there are heat pads on the tanks but that really doesn't do any good for the waterlines, that is were a heat duct comes in. My old unit had the same setup, 1 1 1/2 inch duct and it did indeed keep the water lines from freezing. When it is below 32 degrees that furnace will run a lot.
09-17-2011, 08:10 PM
The storage area where all the water lines run is not heated. We run ours in winter -40 below but do not put water in the system. We use antifrieeze in the holding tanks poured in through the toilet and then to use the comode we just pour water to flush until we get to a climate where we can dewinterize.
09-18-2011, 02:05 PM
Member-at-Large
If you're using it in the cold are you familiar with the Pirithose System? We saw them at the Hershey RV Show and I was quite intrigued by their product. It keeps the water moving and free from icing from the shore into your coach. Anyone using this system?
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 452 |
| 89 members and 363 guests |
| 1f150fan, 2lvrvn, 4bnabird, Barney1, bean, bjcohn, bjlowe, BlakeB, BradinOhio, Cafjackracing, capucine, chof16, cmptrkd, COcamper, DAISY BOYKIN, danred, deerslayer, Dodge Guy, f1100turbo, Falcon35, Filthy Beast, fonzie, gljurczyk, GMS, Greene, grhodes50, Gulay, Hamblen, Harley08, hd87sportster, HemiCab, herk7769, highwayman, hoffkm, hokiecampers, hotrodj125, huricane, jamiller45, jaxfl, jaygeo1, Jim Hair, JohnHoaglun, Joseph5410, jtstromsburg, Juss82, kingranch, kybaja, KyDan, LFugate, lindy, lochsa, Mad4sax, MegaCabby, melbornj, micalo, mike54, MilCop4523, mtusrsmith, nailit, pandkm, ParkManCan, Pkdennis0504, plein air artist, railstar, realebill, redfox217, Redheaded blue tick, rglickman, rhunnell, Rickstermn, RV Guy, sabre5er, sail2liv, sandpiper, sellis1053, ses, shrimper, Silverado09, skidoonut, sledhead77, southernsky, tcoop48, thomeyer, tking1866, tlc, Triguy, UPGRADER, wagon52, Wildhog56 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
