Old 11-20-2012, 08:06 PM   #11
TURBS's Avatar
Originally Posted by Trempert View Post
I tried the bottle trick - it didn't work. It stopped the water flow (antifreeze) from leaving the filter housing as it got sucked up to the top. Maybe I need to have the bottle upside down? I ended up just taking the bottle out and using an extra 12 ounces of antifreeze, but I'm curious what others have found out.
lol upside down is the trick !
Old 11-21-2012, 09:53 AM   #12
thanks. I do see the third valve in between the other two. Hopefully this will be the by-pass to divert the flow of anti-freeze to the tank. thanx.
MattM is offline   Reply With Quote
Old 11-26-2012, 02:11 PM   #13
My 2011 330 only has two valves. One is for the suction hose for the anti-freeze and I can only assume the other is to turn off flow to the water heater. Always thought you needed three valves, cold in, hot out, close them and open by-pass line to rest of plumbing.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 11-26-2012, 03:47 PM   #14
My 2011 378 has two valves near the water pump, one to open the suction hose for antifreeze, the other shuts off the fresh water flow. However, there are also 3 valves near the hot water tank to divert anti freeze from filling the tank. They are hard to see and reach.
ohiobill is offline   Reply With Quote
Old 11-26-2012, 06:38 PM   #15
My rig has three valves on water heater and after closing the hot and cold inlet, the middle valve is the by-pass. Everything went well, even winterizing the refrig with ice maker and water dispenser. Not as difficult as you'd think. Matt
Old 11-26-2012, 07:17 PM   #16
Tim & Lisa Trempert
Sherman,
The other 3 valves for the water heater are accessed from underneath the RV where you will remove another round, white 4" access panel and reach inside behind the water heater.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 11-28-2012, 10:18 AM   #17
Thanks Trempert, will have to check that out when I get home tonight.
sherman12
Old 11-28-2012, 04:44 PM   #18
Evening Update, Yep found the access port, less than 2 minutes had the hot water by-passed. Thanks again my good friend Trempert!
sherman12
Old 11-28-2012, 05:47 PM   #19
If you use a water or pop bottle to take up space in the water filter, fill it with water and it will not foat and block the flow.
Bloomington MN
Rockwood 2304S
TV is a 2014 F150 5.0 V8 with Equal-i-zer
jwuertz is offline   Reply With Quote
Old 11-29-2012, 10:55 AM   #20
bend302's Avatar
I have heard that old golf balls work to fill the filter space. I know they don't float.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
