Old 10-26-2012, 12:57 AM   #1
winterized georgetown
howdy:i drained water heater and left rod out,took filter out and drained canister reinstalled without filter,drained water tank,opened all water valves on sink,bathroom.and shower inside and outside.turned all valves behind water tank and pumped pink stuff through lines worked real good.took water line back of refer and left line off. i think i got it.only problem i have is that motor home has a lot of moister inside so i opened front and back door of shop and it all went away about 3 hours later.these things need air and a lot of that. Pete
petey is offline   Reply With Quote
Old 10-26-2012, 09:21 AM   #2
harleyguy's Avatar
Make sure to do the city water inlet also. With the pump off. Pull the screen off on the city water inlet and press the button. You should get a few drops of antifreeze. Also if you have a black water rinse make sure to blow it out with air or use a hand pump with anti freeze. We have 4 dri z air containers in the trailer that remove moisture that really work well. Got them at camping world
harleyguy is offline   Reply With Quote
Old 10-26-2012, 10:35 AM   #3
fonzie's Avatar
petey, if you have ice maker, you should look at this thread, post #5 and PDF document page 12 and 13....good luck
Winterizing Ice-maker
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 10-27-2012, 09:12 AM   #4
SAMs club sells a nice multi pack of moisture absorber cans with refills. I put one in fridge and one in freezer after I defrost and towel dry the melted frost. Then I put the cans in and shut the door. Any residual moisture gets sucked up and no odors or molds. If you buy two kits your entire coach will be dry as the sahara.
TV: 2012 Silverado 3500HD DRW Duramax/Allison
FW: 2013 Sandpiper 365SAQ
fschambe is offline   Reply With Quote
