Old 10-31-2014, 07:40 AM   #11
We followed the directions and found them helpful - only questionable item is that darn refrigerator (with ice and water in the door). We never saw pink ice cubes - only slush in the ice cube tray. Figure that was because the anti-freeze was in the lines? Everything else went well and was pretty straight forward. We have it in storage now until the end of January when we head to Florida -- hopefully dewinterizing will be easier!
Amazon is offline   Reply With Quote
Old 10-31-2014, 09:21 AM   #12
Amazon:
The water filter takes the pink out! Found that out after putting in 6 gallons of antifreeze and no pink.....LOL
Billr is offline   Reply With Quote
Old 10-31-2014, 09:27 AM   #13
Oh glad we aren't the only ones -- We also put 6 gallons of antifreeze in waiting for pink -- we figured the antifreeze was in the refrigerator by feeling the water coming out from the water dispenser in the door (felt oily).
Old 10-31-2014, 09:42 AM   #14
Happily Retired Member
By blowing out the fridge lines and then closing the water supply valve to the fridge, you should not have had to run anti freeze through the fridge lines.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 10-31-2014, 01:18 PM   #15
Krazymace's Avatar
Took me 2 gallons to winterize mine this year, even though I forgot to remove my filter!
Krazymace is offline   Reply With Quote
Old 10-31-2014, 04:10 PM   #16
Wonder where the water turn off on the 328 is???? I looked under the sink no dice. Any ideas?
k3wtf is offline   Reply With Quote
Old 10-31-2014, 06:29 PM   #17
Krazymace's Avatar
Not sure there is a shut-off. All I have are Bypass calves for Hot water.
Old 10-31-2014, 06:42 PM   #18
On the refriderator
Old 11-01-2014, 06:10 PM   #19
The valve is to the right of the frig. Remove the bottom drawer and you have an access cover. The shut-off is behind the access cover. You have to get down on the floor and reach back to run the valve on and off
scivilla is offline   Reply With Quote
Old 11-03-2014, 03:06 PM   #20
You're welcome
2014, georgetown, motorhome, winter, winterize
