Old 01-05-2015, 03:41 PM   #1
Winterizing
I am looking for the water heater bypass valve on my 2012 377xl can anyone help
buggy2012 is offline   Reply With Quote
Old 01-06-2015, 06:19 PM   #2
Tim & Lisa Trempert
Climb under the RV where the water heater panel is. You'll see a white circular (about 4 inches) that unscrews. Open it and you'll find 3 valves. Switch the position on all 3 valves. (Assuming they were in the correct position to start with)
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 01-06-2015, 07:00 PM   #3
Valving goes like this;
RV Water Heater Bypass Systems
Old 01-07-2015, 05:47 PM   #4
Krazymace's Avatar
Mine is a 3 valve system. Assume yours is as well. Close the cold water in and hot water out valves. Open the 3rd one. That bypasses the HW heater. There is also a valve back near the pump that has to be open in order to pump antifreeze through the system.
Krazymace is offline   Reply With Quote
winter, winterize
