Old 10-24-2010, 08:07 PM   #1
Winterizing
I am preparing for my first winter with my motorhome, and probably will be parking it at my home in Massachusetts for the winter. We plan on at least 2 trips this winter, so I want to have it winterized, but easy to get ready for travel as well.
I bought an air compressor and plan on blowing out the pipes to clear the water. Then I was going to drain the hot water tank and leave the plug out. In addition, I was going to add anti-freeze to the sink traps, the shower drain, and the fresh water, grey water and black water tanks. Is there anything else I should do?
What do people do with the batteries? Take them inside, leave them in the motorhome?
I have the Arctic Pac, if I leave the motorhome plugged in can I forgoe any of the above winterizing steps?
Anything else I don't know about?
Thanks in advance for your help.
Eric
EricBart is offline   Reply With Quote
Old 10-24-2010, 08:37 PM   #2
RV Newbie
buzzards27's Avatar
Did you have the water filter in there? I think you need to take the filter out of the housing at some point, early if you are pumping antifreeze.
buzzards27 is offline   Reply With Quote
Old 10-24-2010, 08:43 PM   #3
Yes, you are right, I need to remove the water filter too. Thanks.
Old 10-24-2010, 08:55 PM   #4
I've taken them inside & they're hooked to a battery tender. It's not possible to leave the TT plugged in over the winter.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
