Old 10-23-2016, 09:54 PM   #1
2006 Georgetown 340
Winterizing Georgetown 340
I started to winterize this weekend. I completed the Hot Water tank draining and the draining of the fresh water tanks. I looked for a bypass valve for the hot water tank and found under the bathroom sink the tank and a single white bypass valve. I did not see a valve for each of the water lines. When I pumped the rv antifreeze, I noticed I kept losing pressure. I went and reinstalled the anode rod and it seemed to pump better.
However, when I pulled it back out, it looks like I have antifreeze in the hot water tank. My question is will this damage the tank? It is a Suburban heater and I think they have a steel tank vs the aluminum of the Atwood. I will drain the tank and flush it with water but did not want to try to pump anything else through the system.
Thank you,
compint is offline   Reply With Quote
Old 10-24-2016, 02:33 PM   #2
No the anti-freeze won't hurt the water tank. The purpose of the by pass is with out it you'll be pumping 6 to 10 gallons of expensive pink stuff in the tank where it only needs to be empty.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
georgetown, winter
