Old 10-01-2016, 11:50 AM   #11
Can someone advise where the refrigerator water shut-off is in 2016 Georgetown 335ds?
JerseyJerry is offline   Reply With Quote
Old 10-01-2016, 01:51 PM   #12
Yep...take out the trashcan under the countertop and look behind the carpeted partition and you will see a white popup valve. I think you push it down to close...or pull it up, I can't remember.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 10-01-2016, 03:51 PM   #13
I found the popup valve but when i push it down it pops back up. Am i missing something?
Old 10-01-2016, 05:18 PM   #14
Does it work if you pull it up?
2015 335DS
Old 10-02-2016, 11:27 AM   #15
We use our camper all year, going somewhere. I let the water pump the ice maker until I start getting pink ice cubes and then I shut off the ice maker until spring, that way I get to still use the refrigerator.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 10-02-2016, 02:20 PM   #16
It is always up and when you push it down it pops back up on its own. It will not stay down. What am I doing wrong or missing??
Old 10-10-2016, 10:14 AM   #17
Iggy's Avatar
If push it down and it still pops up you have not pushed it down enough for it to lock in the open position.
2012 Georgetown XL - 378TS
Old 10-11-2016, 12:32 PM   #18
Thanks Iggy.
Old 11-13-2016, 07:19 AM   #19
2015 377xl
Looking for the water shut off valve to refrigerator in my rig: 2015 377XL. Any help would be appreciated.
slhein is offline   Reply With Quote
Old 11-13-2016, 08:07 AM   #20
WhoDoMan
The water valve for the 377XL is in the storage compartment below the refrig. You may have to remove the plastic cover that houses the elec lines etc
whoDoMan is offline   Reply With Quote
winter, winterize
