Old 10-20-2013, 06:20 AM   #1
winterizing today
378 xl do I just turn off the propane valve before I drain the water heater ,and what if we need the space heater for overnite guests and don't want the w/h trying to come on, will use the coach for sleeping and bathroom only and I can drain tanks next day as we have full hook ups in our rv building next to the house
rwehba is offline   Reply With Quote
Old 10-20-2013, 06:32 AM   #2
You should have a switch that turns off your water heater. That will shut everything off for you. Bypass the lines, drain the water heater, and fill with pinky.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 10-20-2013, 06:41 AM   #3
Herk7769's Avatar
FYI, not all water heater bypass systems have one valve. Some use 2 valves and a check valve, but the 3 valve system shown below yours is the most common.
The anode, if equipped (Atwood aluminum tank water heaters only have a drain), must be removed to drain the water from the water heater. Inspect the anode for remaining life before re-using it.
ID:	41409   Click image for larger version
ID:	41410   Click image for larger version
ID:	41411   Click image for larger version
HAM CALLSIGN - KC3FFW
winter, winterize
