Old 10-04-2015, 06:39 PM   #1
Wiper Blade Performance
Has anyone replaced the wiper blades and wiper blade arms on a 378XL to increase wiper performance?
Even with new blades, there does not appear to be enough tension on the wiper arms to force the wiper blades against the windshield to effectively clear the rain.
I searched the forums and did not find anything. (poor search on my part?)
surcy is offline   Reply With Quote
Old 10-04-2015, 08:52 PM   #2
I noticed the same performance issue with ours. I replaced just the rubber part of the wiper with those single blade types, didn't help at all because of the lack of pressure on the windshield.
I also have an issue with the way the water squirts out. Not a good coverage of washers solution.
Hope someone post a fix.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 10-04-2015, 11:27 PM   #3
jergeod's Avatar
After market makes a spring that snaps on the outside of the arm to give them more pressure, NAPA store.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 10-05-2015, 09:49 AM   #4
Iggy's Avatar
I have done this.
The adjustment other than the spring is to look at the solid arm and slightly bend it more to the window for added pressure. This is what I did and it gained more pressure of the wiper rubber on the windshield.
Now it isn't 100% contact at the end of the sweeps right and left but the main center area (more flat area) it does better.
Old 10-05-2015, 12:29 PM   #5
MOLRMEK
John, I have info for 2016 So Cal Rally. I need your E-mail add. George
George & Marcia
2011 Georgetown XL 337 DS
2005 BLAZER ZR2 TOAD
MOLRMEK is offline   Reply With Quote
Old 10-05-2015, 12:44 PM   #6
Iggy's Avatar
Email sent.
Please delete this message as it doesn't pertain to this thread.
Old 10-05-2015, 03:07 PM   #7
I put a lock washer in the break were arm flexes push in on arm and insert,
It puts more pressure in on the window.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
