Old 06-09-2019, 12:16 PM   #1
Wiper controls
Where are the controls located on a 2018 Georgetown GT5. Iíve tried the control on the steering column and nothing.
treese is offline   Reply With Quote
Old 06-09-2019, 07:07 PM   #2
Dodge Guy's Avatar
Should be on the turn signal stalk. I don't believe there is a separate switch.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-09-2019, 07:41 PM   #3
bubbles's Avatar
It is on the turn signal stalk. I believe the fuse for the wipers is fuse #11 in the fuse panel down on the floor by the left hand side of the steering wheel column. But don't quote me on this.
Old 06-10-2019, 08:30 PM   #4
You may have a bad wiper motor. Happened to me. I could hit the motor with a hammer and it would sweep 2 or 3 times. Pull the wipers off the windshield and it would run all day. I replaced the wiper motor and all is good.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 23 days
mogman is offline   Reply With Quote
