Old 05-18-2015, 12:12 PM   #1
wiper will not shut off
HI I have a 2002 Georgetown and when I got it out of storage the wiper will not shut off . They stay on even when the key is out, I checked the fuses and even installed a new wiper motor and it still does the same thing, Could some one please help me fix this problem . Thanks
dreamcatcher1990 is offline   Reply With Quote
Old 05-18-2015, 01:09 PM   #2
Dijoeboss's Avatar
Could be the multi function switch in column... Remove column covers and unplug the switch asy and see if that stops it. ( turn signal switch )
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 05-18-2015, 02:27 PM   #3
Thanks so much for the fast reply I will go out and do this right now and get back to you. By the way if it is the switch were could I find one ??
dreamcatcher
Old 05-18-2015, 02:54 PM   #4
Dijoeboss's Avatar
Is it a Ford chassis? Ford steering wheel? Should be a ford standard multi-function switch asy....
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 05-18-2015, 05:00 PM   #5
Iggy's Avatar
It's probably the FORD switch where you turn them on and off from.
Old 05-18-2015, 09:23 PM   #6
DiJoeboss, Thanks for your help it was the multi function switch on the floor by the flasher . I first took the steering wheel off and checked the switches and they were good so I pull the multi switch and the wiper stopped. Thanks again for all your help.
dreamcatcher
Old 05-19-2015, 01:56 PM   #7
mike.t's Avatar
What multi function switch on the floor?? You removed the steering wheel and checked the switches?What switches? Does this have an airbag?Boy do i have a lot to learn about these Fords.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-19-2015, 03:52 PM   #8
Mike T : I took the steering wheel bolts and checked the 2 switches on the turn signal and they still worked. So I looked down on the floor by the gas pedal and the are 3 switches from right to left the 1st is the for the dinger the 2nd is a wiper multi function switch that controls the wiper for it . Ford wants $231.00 but I found the same thing on E-Bay for $ 80.00 PS the 3rd switch is the flasher unite.
Old 05-19-2015, 03:59 PM   #9
mike.t's Avatar
Thanks dreamcatcher.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-19-2015, 11:12 PM   #10
Dijoeboss's Avatar
Are you talking about relays?? I'm not following you on "switches on the floor" ? Got any pics??
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
