Old 10-10-2015, 05:08 PM   #1
Vince and Charlette's Avatar
Worth switching to 22.5" tires?
Somewhere in 2015, it appears FR changed the Georgetown tire size from 19.5 to 22.5. My 2015 came with the 19.5s. I currently have 10k on my tires and continue to be bothered by "sway". I've added a steering stabilizer, rear track bar and new heavy duty anti-sway bars front and rear. Also, FR paid for a wheel alignment and I keep close tabs on tire pressure. All of this has led to only modest improvement, and the coach continues to wander all over the lane. Does anyone have experience going from 19.5s to 22.5s. I'm trying to figure if new tires, wheels and simulators are worth it. (We love our 364 and plan on keeping it for quite a while.)
Vince and Charlette is offline   Reply With Quote
Old 10-11-2015, 04:52 PM   #2
I think only the GT had 22.5" tires. Have you done the "Cheap handling fix"?. Worked for me. I drive one handed straight as an arrow.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is online now   Reply With Quote
Old 10-11-2015, 05:12 PM   #3
I recently had to replace one 22.5 tire. The Michelines are impossible to find. Went with a Toyo as had no choice.
2014 GT 378 XL
2005 Jeep Wrangler Unlimited
jeffv003 is offline   Reply With Quote
Old 10-11-2015, 07:40 PM   #4
Mogman, I tried the CHF and it caused the anti-sway bar to contact the frame in turns. Big rig alignment shop said they had to undo two or three other GTs for the same reason. Besides, putting in the heavy duty sway bar should have had about the same effect as the CHF. (Comments welcome.) Do you have 22.5 inch tires?
2018 Berkshire 38A
Old 10-11-2015, 08:36 PM   #5
No, mine are 19.5. I do have any other mods to the chassis.
2003 Dodge Dakota
Hampton Roads VA
Old 10-11-2015, 10:18 PM   #6
Wow Mogman? Maybe we just have different standards.
2018 Berkshire 38A
Old 10-12-2015, 02:15 PM   #7
Tires or suspension?
You may want to do some research on something like Firestone Ride-Rite load levelers. We first used these on a pickup when we had a slide-in camper. It made a tremendous difference. We have put them on two vehicle since to haul a cargo trailer. To our amazement, our new RV has them as standard equipment. These not only level a load, but they make a lot of difference with sway. We are towing a 19' boat with our RV and they are doing the job. Just a thought.
PenJoe is offline   Reply With Quote
Old 10-12-2015, 04:10 PM   #8
Our 2013 came with 22.5's. 251XL. It also wanders all over the road.
Dc8mdtmech is offline   Reply With Quote
Old 10-12-2015, 07:46 PM   #9
I appreciate the input that both of you provided. Load-levelers sound great, but I have to wonder if they are worth it based on Dc8mdtmech's comment.
2018 Berkshire 38A
Old 10-12-2015, 08:00 PM   #10
I am sitting here looking at my 2011 378TS which came from the factory with 22.5 Michelin tires. I to experienced wandering until I had the front end aligned, just a little toed in, then put 95 psi in each tire, then did the CHF. The difference was very significant. Before you spend a lot of money on add ons, try this.
Jmho, Happy Trails,
Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
tire, tires
