Old 11-10-2014, 03:16 PM   #1
Question wrinkling of fiberglass roof on the edges of 2010
Hi gang!
We just bought a 2010 337 and have had it a week. Love it!
I did notice on the roof as I was caulking it....all the way up each side the fiberglass is wavy from the edge in about 4 inches. Anyone else experiencing this.........doesn't seem to cause a problem as far as I can tell.
Also, what do you do for a satellite connection? They seem to only supply cable connections in the basement area. Does anyone know what the white coax cable is in the stereo and tv equipment area
Already done some mods..............made a door holder that keeps the door straight out instead of covering up half the beautiful living room window.
Going to make a shoe storage compartment just to the left as you enter.
I've just got to get that thermostat out of the electronics compartment. Does not register correctly at all. What a hair brain place to put it.
Well..........guess I will sign off and wait for any answers.
Later,
Kurt
kurtm is offline   Reply With Quote
Old 11-10-2014, 03:24 PM   #2
Witch Doctor's Avatar
First things first is your 337 a MH, TT or 5th wheel and what make, by the way. your at the right spot to find out.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-10-2014, 03:31 PM   #3
Fulltime family RVer
Glenn, he posted in the Georgetown forum, so I'm assuming a Georgetown 337 motorhome.
Old 11-10-2014, 04:21 PM   #4
kenandterry's Avatar
Kurt.......
First off........welcome aboard.
You might want to improve your signature to include the specifics of your rig for future communications, as details are always helpful when we assist.
Can you post pictures of the fiberglass defect you're talking about?
As far as satellite connections..........some rigs have a raw coax termination located in a vent stack on the roof just for the possibility of installing a rooftop satellite. Aside from that, you can connect your satellite coax from a ground dish onto the coax termination you mention in the basement, and the other end is this coax you mention in the stereo/tv equipment area.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-10-2014, 05:24 PM   #5
pictures won't show anything...........only about a quarter inch high and four to six inches in length over and over again for the full length.
the cable connections in the basement are just that for CABLE TV. won't work with satellite dish due to inline splitters.
oh............yes 2010 337 GEORGETOWN MOTORHOME.
Kurt
Old 11-10-2014, 05:43 PM   #6
Carknocker Family
Ida Ratherbe Camping's Avatar
Welcome from a fellow Arkansan!
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 11-10-2014, 06:42 PM   #7
borba's Avatar
hi kurt as for the satellite I just install one on my MH automatic one and my tect had to install all new coaxs and wire for power as for the vent pipe on the roof were the coaxs are its only good if you install a ( Dome satellite its prewire ) I was told hope these helps
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 11-10-2014, 06:58 PM   #8
VinceU's Avatar
Originally Posted by kurtm View Post
Hi gang!
Later,
Kurt
The bumps are harmless, if they crack is when you get trouble. Caused by body movement, most likely to crack in the future. I doubt if still has warranty coverage. I'd use self leveling Dicor sealant. Lots have had this problem in the past.
Old 11-11-2014, 09:23 AM   #9
Iggy's Avatar
Kurt does it look like this?
This is on my 2012 and hasn't changed but I keep an eye on it.
Rear passenger side near my ladder.It is normal? Not sure.
I just keep an eye on it.
Old 11-11-2014, 06:36 PM   #10
BillMFl's Avatar
My 2012 360 came with wrinkles for about 3 ft along the rear edge on the drivers side. Looks to me its due to excess width of the fg material along that edge that was forced to buckle during installation. Nothing to worry about unless it develops cracks. Same thing can happen with a rubber roof. Excess material will buckle. If it isn't leaking just check it for cracks now and then and apply the correct sealant if signs of thin cracks show up.
BillMFl is offline   Reply With Quote
roo, roof
