Old 02-03-2016, 11:41 AM   #11
Dr Travel
Nope, you don't have XM
Big diff between XM and XM ready. You have to buy the missing part. Contact your dealer (good luck!) or better still, Georgetown directly. They should have that part in stock. Or you can get a better price online via eBay by searching for your particular radio brand/model. Usually about $200 or so. Maybe less!
Then you have to add a good antenna. The one the factory puts in is useless. Once again, find an antenna online that goes with the XM unit you buy, then find a good RV guy who does electronics and have him snake that antenna up along your windshield to the roof. Easy fix and you will get XM everywhere.
robsshots is offline   Reply With Quote
Old 02-03-2016, 11:49 AM   #12
AquaMan's Avatar
I found the tuner for $50 or less, and I bet if I call XM they will probably give me one. I will most likely try my antenna first, provided there is one.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 64
Old 02-03-2016, 12:06 PM   #13
7 Year Class A RV'er
Can't be sure about the GT'sbut the Legacy is XMReady, meaning you provide the receiver and antenna. Simple install but no good location for the antenna so reception stinks when driving north. Receiver is like $45 at Best Buy.
2015 Legacy SR340 360RB
Old 02-03-2016, 12:43 PM   #14
xm radio
Originally Posted by AquaMan View Post
Does anyone know if the xm radio in the GTowns is connected and/or has an antenna? I tried to get my radio ID and have been unable to do so. My only guess is that there isn't an antenna for it, or it's not connected. Thought I would try here before I tore the radio out to see.
The xm or sirius ready radio will not open the xm or sirius channels unless the antenna/control box has been installed. It senses the signal, so if your radio does not identify the xm/sirius stations, you need to add the control box/antenna, whichever is missing.
Happy Trails, Forrest
Happy Trails
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is online now   Reply With Quote
Old 02-03-2016, 01:43 PM   #15
Senior Member - Retired
Our GT XL came with the XM box installed. Unfortunately the antenna was stuffed up under the dashboard which prevented the XM unit from activating properly. Had to run the antenna wire up to the roof and mount the antenna near the right front of the roof. Then everything worked great.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 02-03-2016, 02:53 PM   #16
XM Radio
I was told that there is a slot for the XM ant. in the roof but there is not, So to run the wire ..take the panel off the side of the windshield, run the wire up into the cabinet and the through the roof. You may have cut a hole for the wire if you can't find a hole for the wire. It does require a metal plate for the ant. to sit on.
Dogpound is online now   Reply With Quote
Old 02-04-2016, 06:08 PM   #17
Well we had a similar issue with our 2014 377xl. The ant was stuffed up behind the dash unit tie wrapped in a neat ball. I returned the unit to the dealer and they installed it correctly. Our ant sits on the dash center. Hope this helps. Good luck!
whoDoMan is offline   Reply With Quote
georgetown, radio
