Old 06-26-2013, 06:47 PM   #11
2012 Georgetown 378
raycyn778's Avatar
I have never heard or seen a step light on a 378TS. mine is a 2012 and I do not see one and I have been under mine many times
Ray, Cynthia, Duncan and Bailey
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
raycyn778 is offline   Reply With Quote
Old 06-26-2013, 07:45 PM   #12
Tim & Lisa Trempert
Originally Posted by leomosley
You should find a blue wire that is not connected if you look under your steps. This wire is called the "step light switch". If you want the step light to come on with your porch light, you need to connect the above wire to the porch light circuit. On my coach, it was fairly easy to feed a line from behind the porch light switch to the blue wire on the step. Connect the wire to the switched output of the porch light and to the blue wire. This wire being unconnected does not seem to be that unusual. Once you make this modification, you can show everyone that your coach is better than theirs ( ie. it's the deluxe version).
Great idea!! Thanks for sharing.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-27-2013, 12:26 AM   #13
thanks for all the answers this will help. I will turn on step light with door open and see what happens. These coaches are a blast and sometimes are a bear also. Pete
petey is offline   Reply With Quote
