Old 05-10-2014, 08:13 AM   #1
Yet Another Tip - Water Heater
When I dropped off the coach to have the awning repaired the lady that helped me get checked in asked if I wanted them to install screens on the water heater exhaust ports. I said no because it's a no brainer DIY and I'm sure they would have charged me a pretty penny to do so.
Once I get the coach back I'm going to add them myself and will post. We do have problems with mud daubers in our area and couldn't imagine what they could do if they decided to get in there.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-10-2014, 08:57 AM   #2
Plain Old Member
While you're screening, might do the furnace, fridge, AC covers, and gray / black tank vents as well. I never thought it could happen, but I had the dobbers trying to build in one of my vent pipes last year. Talk about aggravating hearing that buzzing inside a wall. I removed the little caps, hot glued a piece of aluminum screen to the top of the pipe (cut the same size as the pipe OD), then reinstalled the cap. Those suckers will build anywhere.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-10-2014, 09:01 AM   #3
Rear bumper caps also! Youroo!!
Old 05-10-2014, 09:16 AM   #4
True, true, thanks for the tips.
Old 05-11-2014, 09:22 AM   #5
WFD
Just keep a very close eye on those screens that they dont get plugged up with dust and airborne "stuff"...so that everything can exhaust as it should...there is a potential to start a fire if neglected.
WFD is offline   Reply With Quote
heater, water, water heater
