Old 01-11-2015, 05:01 PM   #21
People in the south have no idea how much winter messes up roads. You can build a new road and 5-6 years it a mess. Winter always wins. We have the same issue in MI and we complain a lot about it also.
Old 01-11-2015, 07:55 PM   #22
LKicklight's Avatar
Tires and wheel bearings
What I have learned from our experience is this, be sure to have your wheel bearings really cleaned, inspected and greased, plan to do it again at 12K miles when you get to that mileage. Also, if you do not have shocks on your coach, install them before you go. I believe the excessive bounce causes the tires to take a terrible beating, also, check your pressures everyday. Also, I would have some air bags installed on your tow vehicle, sure would make the rough road ride a lot better, trust, these things we will do before we ever go again....also, check to see where your ac/dc and propane lines run in advance, make sure if you do have a tire failure they will not get trashed, like ours did..
kickster
Originally Posted by Kampnnit View Post
We are heading to Alaska from Florida early this summer. Tires was one of my big concerns. I upgraded the Chinese tires it Michelin XPS Ribs. I had them on my last camper and there were great.
Name:	10-VIEW FROM REAR.JPG
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 02-04-2015, 01:35 PM   #23
If your planning on taking any side trips in Alaska and you should, a few extra tires on rims might be a good investment. Your can always use them as replacement tires in the future if you keep them stored in a dark, dry place when you get back.
rthomaslyons
2015 Flagstaff 26FKWS
rthomaslyons is offline   Reply With Quote
Old 02-05-2015, 03:01 PM   #24
LKicklight's Avatar
SHOCKS...if your coach is a 5th wheel or travel trailer, I would in vest in either a good set of shocks or air bags on the coach..eliminating the bounce from the roads thru the tires will prove beneficial in the long run..if we ever go again, this will be a must..!!!
kickster
canada
