Old 08-27-2015, 04:54 PM   #21
Originally Posted by MeepMeep View Post
I dealt with the problem of getting dumped on when initially removing the cap by installing a gate valve like this:
Those do cut down on the amount of a surprise, but you still have a mess to clean up.
Old 08-27-2015, 05:47 PM   #22
Mddle of the Rd Extremist
MeepMeep's Avatar
The idea is to keep the valve closed until you get the stinky slinky all hooked up, then you open the valve.....any mess left in the pipe goes directly into the slinky and not on you or the ground
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 08-27-2015, 06:23 PM   #23
HONDAMAN174's Avatar
Be sure to check the valves before or during setup. I have had "someone" open my valves while my unit was in storage. I'm grateful that I saw it before anything hit the tank!
Just glad to get away
Old 08-28-2015, 01:14 PM   #24
Dave Lyon's Avatar
A clear 45 degree elbow is a must as mentioned. I fill up two 6 gallon water jugs and leave them in the shower stall prior to entering the dump station.
After the black tank has been emptied, but the valve is still opened I dump one jug down the toilet to flush any residue. Close the valve and dump the second jug down with my Calgon/laundry mix.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 08-28-2015, 01:40 PM   #25
MilCop4523's Avatar
Originally Posted by oldgold View Post
Or.. Just quit pullin the valves when you're not hooked up!
DW as a rookie asked if she opened the cap to hook up would anything come out before she removed the lid.
NOOOOOO! its been emptied already.
I guess that was the first time i was wrong.
We watched a guy with a 500,000 motor home pull up to dump after the NASCAR races in NH in 2013.
His hose was 6 inches short of where the dump hole was and he still pulled the lever - running back to the hose to try and Arc it in.
it beat him to teh end and he then pulled off the other end at the coach and started to yell at his wife.
by the time they were done fighting with each other they were both coated in STUFF and left thehose there on the ground and drove away.
Unit Depreciation... 80%
remember to have fun - and keep it clean. literally
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 08-28-2015, 01:43 PM   #26
AquaMan's Avatar
There are times when you can get a toilet paper dam right at the tank exit, which can hold back several gallons of "tank contents". Last weekend I emptied my rear black tank and ran the flush for 3-4 minutes before a big gush came out, paper dam.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-28-2015, 01:58 PM   #27
What Meep Meep said and uses. With those you don't ever get your feet full of doo doo. You hook your sewer hose to it first then use your valves. Granted some idiot might pull the handle and close it again. Those clear elbows let you see what'ss there before you open the cap.
Pipeman is offline   Reply With Quote
Old 08-28-2015, 02:02 PM   #28
MilCop4523's Avatar
and with the paper dam came a "gluck" noise is suspect.
and
Old 08-28-2015, 02:33 PM   #29
mike.t's Avatar
I took the cap off to dump the black tank and found out the valve wasn't closed from last time.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 08-28-2015, 08:19 PM   #30
I woulda been rolling on the ground laughing had I witnessed that one!!
Out of the spray zone of course!!
Camped: 2017 (Days/Nights) - 30/25
2016 (Days/Nights) - 32/23, 2015 Nights - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
roo
