Old 08-28-2015, 08:47 PM   #31
mike.t's Avatar
Originally Posted by MeepMeep View Post
The idea is to keep the valve closed until you get the stinky slinky all hooked up, then you open the valve.....any mess left in the pipe goes directly into the slinky and not on you or the ground
Yes. However every once in a while the valve was left open.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 08-28-2015, 09:10 PM   #32
mike.t's Avatar
Originally Posted by MilCop4523 View Post
DW as a rookie asked if she opened the cap to hook up would anything come out before she removed the lid.
NOOOOOO! its been emptied already.
I guess that was the first time i was wrong.
We watched a guy with a 500,000 motor home pull up to dump after the NASCAR races in NH in 2013.
His hose was 6 inches short of where the dump hole was and he still pulled the lever - running back to the hose to try and Arc it in.
it beat him to teh end and he then pulled off the other end at the coach and started to yell at his wife.
by the time they were done fighting with each other they were both coated in STUFF and left thehose there on the ground and drove away.
Unit Depreciation... 80%
remember to have fun - and keep it clean. literally
Your wife is a trooper.Was she waiting to do it?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 08-28-2015, 09:47 PM   #33
dj3spots's Avatar
Take a large zip lock - if you can find a 2 gallon one, great as it's likely not more than that. You can also use a heavy duty garbage bag.
Put the opening up and around the sewer cap. Then, grasping the outside of the bag, twist the cap off. All the "stuff" will dump into the bag which you can then empty down the dumpstation drain.
Keeps your hands neat and clean.
You are the man! Wish we had thought of this when we went to west coast last year. For some reason the dump valve wasn't closing correctly and every time we pulled the cap .... Oh crap! Fortunately, DH always wears gloves and after the first time we used a "TUG" bucket. I've already set out a box of the 2 gallon ziplocks to go into the camper. I even stuck directions on the box in case CRS hits. Thanks.
dj3spots is offline   Reply With Quote
Old 08-29-2015, 01:13 AM   #34
Sagecoachdriver's Avatar
We were up in Yosemite and dumping. Across from us pulled up a rental class C. Two guys got out opened the compartment grabbed the sewer hose and attached it to the sewer valve hookup. They stuck the hose onto the dump hole and pulled the "T". The hose flew off the valve hookup at the MH and covered them in blue stuff making a huge mess. Not knowing what to do I guess, they jumped into the cab and took off leaving the sewer hose. Gosh, they forgot to dump the grey tank!
Anyway, a big DP Class A pulled up behind them and watched the entire thing. The old trooper looked at the DW, got up and went to the rear of the coach. came out the door a few seconds later with boots and gloves on and went over threw the hose in the trash and hosed down the area. Had the DW pull the MH up when he was done washing it down. My DW asked, you would have done the same wouldn't you? Of course, I replied?????
Now I wonder if she meant leave it and run or clean up the mess they left?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 08-29-2015, 10:03 AM   #35
mike.t's Avatar
Good stuff sage
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 08-29-2015, 10:27 AM   #36
Scubanut's Avatar
These stories made me chuckle. I had my experience with the paper dam a few years back with the grandkids before I taught them less is best. I couldn't get my black tank to dump at all and I knew it was full. I used my flexible tank rinse hose and went at it from the dump side. Needless to say it let loose and I had a heck of a time reconnecting the slinky. My first shower with poo juice. Yuck!
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 08-29-2015, 05:24 PM   #37
bareftn's Avatar
Originally Posted by OldCoot View Post
That's why you semi permanent mount a clear elbow on the discharge. No surprises.
where can one it for my camper?
bareftn is offline   Reply With Quote
Old 08-29-2015, 06:18 PM   #38
Old 08-29-2015, 06:40 PM   #39
Fulltime family RVer
Almost all RV stores have them and many RV sections of Walmart and the like have them. Lately, Amazon has been my go to for RV stuff.
Old 08-29-2015, 11:52 PM   #40
Pockets
I would leave about 4 or 5 gallons of water in the BWT at all times. Keeps the solids from getting really solid.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg
2015(36 nights) 2016(74 nights) 2017(174) 2018(105 nights)
Pockets is offline   Reply With Quote
roo
