Old 02-07-2014, 07:27 AM   #11
caper's Avatar
I have traveled that area pulling a 34' TT. Had no problem, it is hilly and a lot of turns but doable. I have also taken the route through the US. The south road has less hill and a lot less turns. They have done a lot of work in northern Ontario by making some of the turns not as sharp and trying to lower some of the hills by blasting away the hill tops. I also carry a spare tank of gas because the first year we traveled west ran out of gas 20k from Wawa.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-07-2014, 05:25 PM   #12
Mmnsc's Avatar
Thanks for all the valuable inputs. As a result of all your information we will NOT be traveling that route instead we will be cutting across North Dakota and route south around Lake Michigan to finally wind up at the International Rally in Goshen. Thanks again
Mmnsc is online now   Reply With Quote
Old 02-07-2014, 05:47 PM   #13
Just a quick note about N.D. lots of oil const. going on so watch your c.g. as most are not c.g. anymore. We drive N.D. every year.
Kdcamper
kdcamper is offline   Reply With Quote
Old 02-07-2014, 10:43 PM   #14
WFD
Its almost impossible to find a campground/rv park with open sites in western ND and eastern MT due to oil workers taking it all up...even Walmarts have had to kick campers out because too many were taking up residence in the lot and making a filthy mess.
You should be ok around the Grand Forks, ND(you likely wont be that far north though) and Fargo, ND areas.
Rick
WFD is offline   Reply With Quote
Old 12-27-2014, 11:14 PM   #15
Turn South on Hwy71 east of Kenora and go through Sioux Narrows, Nestor Falls, Fort Frances and Atikokan then to Shabqua 40 miles west of Thunder Bay. It's more scenic and you miss a lot of the Transcanada highway and it's not much further
John
Atikokan, the Canoeing Capital of Canada
2012 Windjammer 3008
Factor is offline   Reply With Quote
canada
