Old 05-27-2015, 12:46 PM   #11
TURBS's Avatar
Originally Posted by DickiedooFlagman View Post
You didn't say if the engine was running, or not. A key on and engine not running will give a battery light on
True that!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "9 nights"
Old 05-27-2015, 12:48 PM   #12
mike.t's Avatar
Well bob take the alt. off and have it checked. If it is no good as you assumed replace it and get out on the road. I guess i don't understand the question. Are you asking how it could happen by simply replacing the battery? Guess you could have fried it by shorting something out. If it's bad it's bad.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-27-2015, 01:37 PM   #13
mike.t's Avatar
Originally Posted by bob caldwell View Post
Batt. light on......just love it when someone's hav'in problem and needs answers or ideas what to look for.......and, THEY'RE not even on line!
Guess he realized if it's bad it needs to be replaced.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-27-2015, 02:15 PM   #14
Originally Posted by Dave T View Post
I replaced the engine starting battery in my 2009 E450 V10. No sparks or any other problems. It was a simple replacement! Now the alternator wouldn't charge! Help! Need to hit the road today.
Is the battery installed correctly ? Pos + Red cable. Neg - Black cable?
EdnKat is offline   Reply With Quote
Old 05-27-2015, 03:03 PM   #15
Left Coast
As Turbs asked, if you have 12Volts @ big post on back of Alternator.......12 volt test light would work.
Old 05-27-2015, 05:48 PM   #16
mike.t's Avatar
post #12 should have read Dave not Bob
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-27-2015, 08:55 PM   #17
Too old to be too smart
SpringerPop's Avatar
In today's world of auto parts stores, it's not uncommon AT ALL to get a bad unit right out of the box. They are "rebuilt" (and I use the term very loosely) for next-to-nothing, and with labor that gets paid about the same.
Typical wisdom on the Ford boards is to take yours to your town's "reputable rebuilder" and have him go through your old one. Far better, long-lasting results are to be had that way.
Life-time guarantee? Sure! They couldn't sell that crap at all without one!
The only thing I can add, assuming your "new" alternator is really OK, is that Ford uses a fuse (usually 5-amps) in the field wire. Look in your Owner's Manual to find which one it is.
Oh, and rarely (but sometimes) the small connector on the alternator has pins that get loose with the constant vibration. They lose their "tension" and you end up with a bad or intermittent connection. The connectors are available separately to enable you to splice a new one in place if that's the case.
But I'd be first looking for a bad out-of-box unit.
Ford 6G alternators are good units, but the domestic parts-house rebuilds are usually crap.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 05-27-2015, 09:10 PM   #18
mike.t's Avatar
Springer. Unless i missed something he didn't replace it yet. Many aftermarket companies are making new one's they are not as much as they use to be.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-27-2015, 09:11 PM   #19
TURBS's Avatar
Until we hear from the op I guess we'll not know. .....m
TURBS
Old 05-27-2015, 09:16 PM   #20
Left Coast
I love lost causes.
charging
