Old 05-17-2015, 04:46 PM   #1
Battery compartment components
Decided to clean the batteries, cables etc and wound up in trouble. Pulled both batteries and tried to remove something - maybe a relay, a number U-21-H is stamped on back? - attached to the left wall and broke it. There are 2 (over and below each other) with red battery cables and the 2nd wire goes thru the wall. The local RV dealer advised me to call FR (do have a call in, waiting for reply) and find out the amps. Anyone know what this parts are and what amps they are? Hope this makes some sense. Thanks.
ljcpmc is offline   Reply With Quote
Old 05-17-2015, 05:05 PM   #2
Broadway Joe's Avatar
Pics are worth a thousand words.
Broadway Joe is offline   Reply With Quote
Old 05-17-2015, 07:00 PM   #3
Thanks, I will post a picture of the component and the compartment
Old 05-18-2015, 08:36 AM   #4
jevanb's Avatar
They are terminals strip. When the manufacturer needs to join 2 terminals together they use them. If you have room on another put your wires their..BTW relays will have more then 2 wires, what they control and controlling wires
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-19-2015, 07:13 PM   #5
Success
Success - Forest River tech came thru, sent pics and he identified the components as 30 amp terminal relay/strips. Bought the parts today and will install sometime.
battery
