Old 12-26-2014, 05:48 PM   #11
drron's Avatar
No its just an open / close valve in a water line thay goes down through the floor under the bed.
I'll take photo and post it
drron is offline   Reply With Quote
Old 12-26-2014, 05:55 PM   #12
Hamm123's Avatar
If it goes down in floor, it sounds like a valve to fresh water tank,, maybe
Hamm123 is offline   Reply With Quote
Old 12-26-2014, 07:36 PM   #13
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
I agree with Hamm123, the valve under our bed drains the fresh water tank.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 12-27-2014, 08:36 AM   #14
drron's Avatar
Thanks guy's, when the previous owner delivered it to me from Mississippi all he did was put a couple of gallons of antifreeze in the potable water tank. I'm in Tennessee , it gets cold.
I think I'll try and blow it all out today and drain the water tank, I already put the required treatment down the Black and Grey.I have a new Anode to put in the water heater, stay tuned
Old 12-27-2014, 12:25 PM   #15
Denver, CO
garbonz's Avatar
The key with blowing out the lines is to be persistent using 40 psi and no more. open each valve by itself and let it blow air for 10 or so seconds and then do each valve like that, one at a time and then repeat the process at least 3 or 4 times.
2017 Fuse 23T
Old 12-27-2014, 04:02 PM   #16
drron's Avatar
10-4 thanks
Old 12-29-2014, 07:41 PM   #17
Ddron congrats on your purchase! I just purchased a 2007 300SS and am thoroughly enjoying it. I have now done both the blowing out method of winterizing as as well as the antifreeze method (installed a winterizing kit under the bed) and both have worked fine :-)
heb1024 is offline   Reply With Quote
Old 12-30-2014, 08:03 AM   #18
drron's Avatar
I found the WH bypass valve under the bath vanity . I just removed the panel and there it was. Hope you enjoy your unit without and problems.
Old 12-30-2014, 08:06 AM   #19
Yep mine's in the kitchen cabinet right with the water heater
Old 01-17-2015, 11:16 PM   #20
We have a 2008 Lexington and the bypass is under the bathroom sink. Remove the panel on the left side and look in the hole with a flashlight and it should be there.
Sherol is offline   Reply With Quote
bypass, valve
