Ceiling vinyl separating What to do
2007 Lexington 283 and the ceiling vinyl is separating from the foam lining. I have taken a divider strip down and checked this. The foam is still attached to the ceiling panel but the vinyl has separated from the foam, the vinyl is sagging in most areas. I have no roof leaks it appears the adhesive has let loose between the vinyl and foam. Any ideas on a fix and who does it. Thanks, Chuck
