Old 07-02-2014, 04:27 PM   #1
dougpatz's Avatar
Cracked caulking over cab
We have noticed that the caulk between the cab and the fiberglass overhang on our Lexington is cracking. What is the best product to use to reseal? Do I remove the old stuff? No evidence of leaks, but trying to avoid a problem.
Patti Z.
2011 Lexington 283
Springer Spaniel - Sheldon
dougpatz is offline   Reply With Quote
Old 07-02-2014, 06:14 PM   #2
Commercial Member
I would use silicone. Paintable caulk was probably used and it is drying out.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
bclemens is online now   Reply With Quote
Old 07-02-2014, 06:55 PM   #3
dougpatz's Avatar
I've been reading old forum posts, and silicone was not advised-only latex. Now, I'm confused. Do I remove all o the old stuff?
Patti Z.
2011 Lexington 283
Old 07-02-2014, 07:01 PM   #4
Commercial Member
It always better adhesion to remove the old stuff, but not always necessary if you're just going to fill the cracks. Just depends on how much time you want to spend on it.
Old 07-02-2014, 07:09 PM   #5
grumpy0374's Avatar
DO NOT USE SILICON!!! Worst thing you can do. It will be hard as you know what to remove, and nothing will ever stick to it again.
1. get some mineral spirits and clean the old caulk. no need to remove
the old caulk, just clean it.
2. get some acetone and reclean the caulk. It will remove any residue.
3. get a caulk tube of Dicor non-sag caulk and apply it right over the old,
and now clean caulk.
I have a 2012 283ts, and just recently did the same thing to mine. Noticed a few cracks. Cleaned it as above and applied a bead of new Dicor caulk and smoothed it down with a wet finger.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 07-02-2014, 07:29 PM   #6
grumpy0374's Avatar
dougpatz, for info Dicor makes two types of caulk, self leveling and non-sag. Both are great products for rv's. Use the self leveling on the roof seams, vents, drip rails, anything horizontal. It will level out on it's own. Use the non-sag on vertical surfaces and seams, like the cap to cab seam.
Grumpy
Old 07-02-2014, 07:35 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
X2
Dicor only!
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 07-02-2014, 08:10 PM   #8
lil2low's Avatar
I was told by our dealer that TSP is the best cleaner/degreaser to use because it does not leave any residue when it dries. And then of course dicor lap sealant to reseal like most have suggested.
lil2low is offline   Reply With Quote
Old 07-02-2014, 08:23 PM   #9
grumpy0374's Avatar
You want to use TSP, go ahead. Of course thats the same stuff I use to clean my concrete walkway with. No way would I use TSP on a fiberglass cap or painted cab surface. Much to caustic. On aluminum it's much worse. Just go with the spirits and acetone. Will clean it and no residue. A quart of each will set you back a few bucks and probably last you for 2-3 years.
Grumpy
Old 09-06-2014, 10:28 PM   #10
Wow bclemens I'm surprised that you would recommend silicone caulking on a MH rather than a product purpose made for RV's
RonnieTO is offline   Reply With Quote
Old 09-06-2014, 10:37 PM   #11
Commercial Member
In that particular spot, that is what I would use. Roof, no.
The area he's talking about is sealed between the cab & cap, so it's really more for aesthetics.
