Old 08-26-2016, 10:05 AM   #1
Door strut
I need a door strut for our 265 Lex. Factory does not answer so need to know length and strength. attach points are still there. anyone?
otisite2016 is offline   Reply With Quote
Old 08-26-2016, 08:14 PM   #2
grumpy0374's Avatar
My Lexi 283ts has a 20 inch, 20 lbs. strut. Not positive, but yours should be about the same.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 08-28-2016, 08:54 AM   #3
Thanks so much Grumpy.
Old 08-28-2016, 10:03 AM   #4
grumpy0374's Avatar
I ment to add....
You can find them on Amazon, just punch in 20 inch, 20 lbs strut, and it will bring them up.
However...
Save the ends from your old strut as the new strut may come with a bigger (in diameter) end. Found out, at least on my Lexi, that a larger diameter end will not clear the door when you close it. The new ends will fit on the "ball", but when you close the door, it may bind because of the larger "end"
Just transfer your old ones, they just unscrew.
Or, you can do what I did. Also from Amazon, pack of 4, GSB 10mm Ball Socket End Connectors.
Their metal, not plastic, are small and very strong.
Grumpy
door
