Old 08-26-2013, 01:11 PM   #11
RV Nomad
OK. I just opened the fresh water tank drain valve located under the bed and saw that the water was draining from a third hose located under the frame. I still don't know how to open the plugs on these two hoses as I tried again, with pliers, to loosen them and they refuse to turn. And yes, I was turning CCW. Do I even need to open them for any reason or should I just forget about it? Thanks for any input.
olygene is offline   Reply With Quote
Old 08-26-2013, 01:16 PM   #12
GM
bclemens's Avatar
Can you hold the base piece? Base should be crimped/compressed onto the pex line (the threaded male part) then try and turn the cap.
Or just cut them off and put a new cap on. Maybe someone glued them??
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
drain, fresh water, tank, water, water tank
