ducted air question
This is the first time we have ran the air . Sitting here in Cut Bank,MT. 82 degrees & need the air. Cooling is good but not much air flow out of driver's side ceiling ducts. Thoughts?
Also AC voltage is just inside the green at 114 volts. Oh yes, the wife just got done using the 1500 watt hair dryer with air going. No tripped circiut breaker, even with the lower voltage.
PS,
Don't take hwy 2 across northern ND. Very wet! Also with the oil drilling & other constructon. It's a zoo around Williston! Gas prices are 30 cents a gallon higher!!
