Old 04-23-2010, 04:07 PM   #1
Elect. problem
I just went on dry run and when I plugged in at campsite I blew the breaker, I shut off my breaker turned theirs back on then mine worked fine on 110 but the 30 amp. keeps popping breakers, any ideas
Old Wrinkles
wrinkles is offline   Reply With Quote
Old 04-23-2010, 04:12 PM   #2
powerboatr's Avatar
i take it your rig is a 30 amp corded unit
if so, make sure your water heater it turned off and the fridge on propane
and the a/c is off
i would bet if the wh and fridge both are on a/c power they are straining a weak 30 amp pedestal breaker, then if you add a load it trips
my fridge will pull 5-7 amps
and wh easily pulls 12-14
add 10-12 for a running ac and your out of amps, not to mention the start up on the ac is probably spiking over 15 at start if not higher
when we hook up to 30 amp pedestals i use fridge on gas and the wh on gas to leave room for the micro and ac.
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 04-23-2010, 04:16 PM   #3
Hi Powerboatr
Thanks for the reply my wh was off as well as refer on gas and the ac was off I wonder if a problem exists with both pole and me having ground faults, just not sure
Old 04-23-2010, 05:49 PM   #4
TulsaSteve's Avatar
Could be an improperly grounded circuit at the campground. Can you move to another slot?
TulsaSteve is offline   Reply With Quote
Old 04-23-2010, 10:16 PM   #5
My rig is 30 amps as well, and your setup should handle everything with no problems. Hey, when wer'e on an electric site, why burn up your propane??? I run my AC, water heater, refrigerator, and the interior lights witout a problem ever in 2 years. Only once I tripped the breaker on the outside box because cooking breakfast with an electric skillet was too much for the system and overloaded it. Turned the air off, and we were fine. The box as stated was probably not grounded well enough. Good luck! Randy
