11-21-2013, 01:20 PM
Electric awning
I am looking at converting my manuel awning to an electric one. Has anyone else looked into this or done it?
11-21-2013, 01:28 PM
albeit that it "could" be done, the arms from each type of awning mount in different locations and most likely will leave holes in the side of your camper that would have to be repaired.
TURBS
11-21-2013, 02:22 PM
Current awning has mounts at top and in rail at bottom. Eliminating would leave holes at bottom to be fill and a plug would work and not be noticable.
Concerned about mount and weight at top with not vertical support.
11-21-2013, 03:04 PM
I'm not clear on what your stating.
Automatic electric awnings mount to the sidewall of the camper .
11-21-2013, 03:25 PM
Have a Lexington Class B+.
Curved where roof and sidewalls meet requiring a horizontal mount at top with sissor type action.
Google Lexington and notice awning support bracket curves just above top od entry door.
This curve precludes using a verticle sction electric awning. Other option is horizontal operating elecrtric awning.
Done my research, just curious if anyone has done this conversion.
11-21-2013, 03:56 PM
Makes more sense now.
There I can't help.
Turbs
11-21-2013, 03:57 PM
TURBS
Why couldn't he just replace the rh end with the motor? Don't know if the lh torsion spring is the same. Could work if the ends would take the new motor, etc.
11-21-2013, 03:59 PM
Good idea.
You'd have to eliminate or disable the forward/reversing mechanism tho.
Right?
11-21-2013, 04:00 PM
Good idea.
Right?
You would pull that entire mechanism out of the tube and replace with the motor mechanism. Only problem would be if the motor stuff would fit the old arms.
11-21-2013, 04:22 PM
The manual awning is more "beefy" than the automatic from A&E. Don't think motor could handle the extra load. From the way mine works, I'm sure it would really struggle with the manual ones I've had before. I feel confident in saying a retrofit to existing manual awning would not work. Actually I think I prefer the manual ones. They can be converted to the carport configuration and secured to the ground for windy conditions and a deflapper installed on each end is easily accomplished. Not necessarily a bad thing having a manual awning.
11-21-2013, 04:39 PM
When at the Rally-------------
When at the Rally in Goshen, the same question was ask bay a fellow from Quebec that was having his Manuel awning replaced with a electric awning. The techs said to completely remove the old awning and replace everything with the new hardware for the electric awning to make sure it all works. Plug all the old holes with Stainless steel lag bolts.
I watched this happen at the 2012 rally.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
11-21-2013, 04:49 PM
Why would you want to do that? except it's easier of course to press a button, The manual awnings are so much stronger. I tried to get them added new instead of the electric ones, I don't care what anyone say's they do not hold up the metal is so light that they will bend with just a little pressure. But that is just me. The person who invents a flopper stopper for the electric awning will become an millionaire over night. Ah! a new project for the old coot to design on his CAD. You got to keep that old man busy or he creates s--t on this forum...
Coachmen M/H
Concord
2018 / 300 DSC
11-21-2013, 04:51 PM
Same can be done with an electric.
11-21-2013, 04:52 PM
Easy fix, just throw a strap over the material and secure on the flimsy arms. Works like a charm.
11-21-2013, 04:53 PM
11-21-2013, 04:55 PM
And a lot easier and just as good. I'll take my electric over the 7 manuals I've had now that we have the poles installed.
11-21-2013, 07:02 PM
Thank you all for your input.
Doesn't take that much time or energy, and way I have done it for past years, just getting older and lazier.
As Kathy Bates said in "Fried Green Tomatoes", I have more insurance and can afford it.
Again Thank You!!
11-22-2013, 10:20 AM
Commercial Member
I think we may have "spacer" wedges that space the awning out to be "flat". So I think this conversion is possible on a Lexie even.
11-23-2013, 12:05 PM
As it turns out there may be a kit to convert from manual to electric. I think it involves replacing the support arms and the roller tube internals. This mod was discussed on other forums. Did not sound like a hard mod to do and certainly a lot cheaper than new. Don't have particulars.
11-23-2013, 01:38 PM
Thank you. Understand that due to curve at top of support arms this was not viable.
Bclmens in previous post stated wedges available. Am looking into it further but would appreciate any additional information anyone might have.
