Forest River Forums
Sunline User Photos
Closed Thread
Old 10-24-2011, 12:15 PM   #1
Dave T's Avatar
Forest River workmanship??
I hate to complain but I have had it with poor workmanship & bad products from Forest River! I drove down from northern Mn to AZ last week. Lost the tail lights & marker lights on the rig the first day! NOT A BLOWN FUSE! Brian was nice enough to email me a diagram & pictures of where Forest River splices into Ford's wiring. I have had no luck finding the splice because the gas tank is in the way & cables can't be traced with foam covering them! I don't think there is any set pattern on how they wire these units because no clear answers from the factory!
2nd day out I had a water leak on the city water connection that eventually got the carpet wet in the bedroom! The fitting coming in was only finger tight!
Now I have a leak on the black tank flush!! I think that is leaking on the ground not inside! It's almost in possible to get at the joint where I think it is leaking!
This is on top of other things I had fixed while under warranty! I know there are people who didn't have any problems. But that doesn't do me any good because I am having their share of problems. I have to vent because that is all I can do!!
Dave T is offline
Old 10-24-2011, 12:21 PM   #2
too fast turbo sled
f1100turbo's Avatar
sorry to hear about your problems dave T
take a deep breath .
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now
Old 10-24-2011, 01:00 PM   #3
Boyd's Avatar
Jeeze, I was going to apply for a job at the FR factory but I'm over qualified knowing which end of the screwdirver is the business end.
The management at FR must be pushing their line people so hard they either skip or turn a blind eye to little things like, putting in screws, tightening nuts, adjusting torque so the screws aren't striped, using the proper color wires...etc...you get the idea. Something sure is amiss where they put these rigs together. In all my years being around different types of construction, I have never seen such constant poor craftsmanship..Quality Control? What Quality Control.
Wish I was there to help you Dave, we could could share the snot rag. Good Luck
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline
Old 10-24-2011, 02:44 PM   #4
Come on people, everything will have problems when it's new if it is at all detailed or complicated. Wiring splices can easily come lose if the solder was not exactly the right temp, or maybe a hose clamp wasn't torqued fully tight, I mean everyone of us has a bad day now and then where things are just off a little bit. I've owned 2 different FR products, and yes I had small issues with both (that's to be expected), and I fixed them all in short order right at home. It's not like a stick build home (which even new ones have major issues) your RV is rolling down the road flexing and stressing all the time. If you ALWAYS expect EVERYTHING to be perfect, the maybe you'd better never buy anything.
2008 Dakota Sport 4x4
2012 Rockwood 2604
2004 Subaru Baja - DW's go buggy
1970's Rupp Ruppster - my field go buggy at home
42 nights camping 2011, 2012 5 nights camped and 28 reserved
F.R.O.G. member
lindy is online now
Old 10-24-2011, 03:05 PM   #5
Boyd's Avatar
There is a BIG difference between small problems, such as you've experienced, and major issues. I too fix the small problems that should never have left the factory but cabinets falling off the wall, slide motors with missing mounting bolts, a dozen nail gun holes without nails resulting in falling trim, multiple screws stripped allowing skirting to fall free, water tanks falling off and the list goes on, will never be address by the factory unless they are held accountable. It's about quality control, and it appears as if FR is sorely lacking in that department. For your sake I'm happy you've never experienced any dangerous or major problems with your purchases, others have.
Boyd is offline
Old 10-24-2011, 03:09 PM   #6
Dave T's Avatar
There's one of you every crowd! Good for you that you only had some minor problems or is that is all you will admit to? Or know about?
Dave T is offline
Old 10-24-2011, 03:19 PM   #7
Dave my new 2012 unit was at the dealers one week before I picked it up. I had a leak at the base of the shower door. The caulker simple missed about a 1/2" seam. Also the radio antenna was not bolted tight enough (for my likeing). We used the unit about 38 days this year on 4 different trips, and no there aren't any other problem either know, not admitted or unknown. That's not to say that on my 1st trip out next year I don't have a problem. If I do OK that's part of RVing, things will go wrong. On my stick and brick I've at work done on the furnace 2-3 times in the last 5 years, does that mean is substandard equipment?
2012 Rockwood 2604
F.R.O.G. member
lindy is online now
Old 10-24-2011, 04:14 PM   #8
I must admit that we have been very lucky with our Flagstaff. We had a loose fitting on the bathroom grey water trap that was caught during the PDI, and a blind that was strung improperly by the Chinese factory that made it (which FR quickly replaced). I did reinforce the steps going up into the bedroom, but that was just to satisfy my ultra-fussy nature. And yes, there is the odd screw in the cabinetry that was tightened a bit too much and partially stripped, but that is a super easy fix. But that is it, no other issues with the function of the camper or quality of construction.
I don't know what the difference is, maybe we just got the best crew that day.
crocus is offline
Old 10-24-2011, 04:25 PM   #9
Rugged Brown's Avatar
I must have had the same crew working on mine. No issues, other than a leaky faucet which was noticed at the PDI. I examined my unit prior to purchase and I was aware of the workmanship. A warranty was provided , should something fail and if you want added comfort, then the option of an extended warranty was offered. If I wanted a better quality product, then I expect to pay more. Same can be said for any product you wish to buy.
Terry/Bernadette
Lily the Yorkie
2010 RAM
2011 Flagstaff 8528 CKWS
Rugged Brown is online now
Old 10-24-2011, 05:18 PM   #10
too fast turbo sled
f1100turbo's Avatar
had only one issue with my palomino sabre first night out ..... fuse blew for slide out .
replaced the next day with a circuit breaker .
since then I had a propane leak that appeared to be "not" tight enough .
2 hour pdi made the difference even tho we were not "first" time buyers we asked questions about everything we saw .
and the major differences between our tt and new 5er .
I guess the palomino line is top notch .
I believe thats the only issues we have had .
Ron and Amy Benhart
Closed Thread
» Online Users: 487
113 members and 374 guests
4bnabird, aquaskiman, autorot8, bend302, biggie, biken201, Biscuit, bjcohn, BlakeB, boubou, buzzmonster, capucine, chof16, Christopher Columbus, cmptrkd, COcamper, cootr68, Crusader, danred, deerslayer, DGrissom, dimurrrw, dummin4fun, Dunefam, dunnnc, EdJunior, f1100turbo, F22, flc, fonzie, gjcamann, gljurczyk, GMS, GRAYSONH, Greene, gregory, Gulay, Happy Campers 79, Happy Vibe, hd87sportster, herk7769, highwayman, hokiecampers, huricane, Itsthetwoofus, J R, jacksum2, jaygeo1, jes520, joess, JohnHoaglun, JohnT, johnthecamper, jtstromsburg, Juss82, Kalacim, kingranch, KKapa, kybaja, KyDan, lbhird, LFugate, lindy, lochsa, Lonewolfcry, Macgyver89, Mad4sax, MayorBobK, micalo, mtnguy, NanaKaren, OffPavement, ohioflyer, Ovair, pandkm, ParkManCan, Pharmofish, pixleys, Pkdennis0504, polkatronron, poohbearntigger2, Ragin Cajun, rawlus, Redheaded blue tick, rglickman, rhunnell, richludden, Rickstermn, rkswyo, ronhanson, Rugged Brown, Rustymax, sabre5er, scout800, Scouter, ses, shurack24, Silverado09, sledhead77, TexasBBQ, tking1866, Triguy, trudinator, tshayn, UPGRADER, Vernk, Vic, wagon52, Warrior, Wildhog56, Wildwood Danny, windrider, wnytaxman
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
