Old 04-03-2016, 06:34 PM   #1
Hasher12's Avatar
Furnace issue
I have a 2003 Lexington 235 class B. My furnace is set at 50 degrees. How do I keep it from turning on?
Hasher12 is offline   Reply With Quote
Old 04-03-2016, 06:45 PM   #2
Ford Idaho's Avatar
Set the temperature to a few degrees below the current air temp.
Heat, down arrow to the needed temp.
Old 04-03-2016, 06:48 PM   #3
Hasher12's Avatar
I have the thermostat at the lowest level...50 degrees. I have the LP off, but the furnace engaged and warmed the coach anyway.
Old 04-03-2016, 06:55 PM   #4
PhoneDude 8289's Avatar
What is the ambient temperature inside the RV? If there is an off button to the thermostat did you try that?
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-03-2016, 06:57 PM   #5
Hasher12's Avatar
I'm note sure. I'm in Texas and the current temp is 73.
Old 04-03-2016, 07:11 PM   #6
Ford Idaho's Avatar
Heat strip?
Old 04-03-2016, 08:55 PM   #7
Send a message via AIM to NoviBill
My thermostat has 3 settings: Off, Heat & A/C. When switched to off it stays off.
I have a propane heater that runs off of 12 volt. Some have an electric heater as part of the A/C unit. Do you know which was running? If the propane is turned off the fan can still run, but you will not get more than a minute of heat (propane in the lines) before it blows cold. Often the heater has it's own 12 volt fuse, you could pull that to stop it.
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 04-04-2016, 07:48 PM   #8
World Wide Wanderer
wahoonc's Avatar
Which thermostat do you have? If the 'stat is OFF nothing should run.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
furnace
