Old 05-31-2016, 03:35 PM   #1
Help identifying dash radio
Can someone give make and model # for this radio?
Can you explain how to set the time?
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
dontay is offline   Reply With Quote
Old 06-01-2016, 06:39 AM   #2
Dave T's Avatar
Magnadyne M1-CD
Press and hold the DISPLAY button at anytime
until the clock begins to flash in the display.
2.
Rotate the VOLUME knob counterclockwise until
the correct “HOURS” appears in the display.
Note:
When setting the clock make sure to
select the correct AM or PM indicator.
3.
Rotate the VOLUME knob clockwise until the
correct “MINUTES” appears in the display.
4.
Wait 5 seconds and the display will return to last
mode displayed.
You can find instructions by doing a search on google.
Dave T is offline   Reply With Quote
Old 06-01-2016, 04:03 PM   #3
Thanks. That worked.
radio
