Old 03-08-2015, 06:35 PM   #1
HVAC ceiling vents
We have a 2008 Lexington 283 gts. On our last trip to Florida we used our AC almost non-stop. We noticed that the driver side ceiling vents from the front through the kitchen, bath and bedroom had minimal air flow. We have only 1 roof mounted AC unit so there is only 1 zone for the thermostat controller to control.
Does anyone have suggestions as to what the problem maybe or possible solutions? Also, are there any tests that I can do to verify the problem?
Thank you for your time and knowledge.
Burnsville NC
gboyle is offline   Reply With Quote
Old 04-27-2015, 01:35 PM   #2
RickLSmith53's Avatar
A/C Vents
I am guessing you have made sure the duct work bypass at the A/C itself is fully closed? It is a little inconspicuous slide that looks like part of the grill that covers the A/C unit on the inside of the coach. It is used for quick cool right below the unit. It only slides about 1/4". But if it is open, your ducts will only trickle... Good luck!
Rick Smith
RickLSmith53 is offline   Reply With Quote
Old 05-07-2015, 09:39 AM   #3
During the pre delivery inspection we had the same problem. The RV technician found the duct opening at the A/C was not fully cut open.
2011 Sunseeker 3100
1997 Pathfinder Toad
RamblerGuy is online now   Reply With Quote
