Old 06-16-2014, 09:02 AM   #1
Inverter question
I have a 2009 Lexington GTS. When I'm running on house batteries with my inverter on none of my outlets is working. I know that my inverter is producing 120 vac because I tested it with a meter and plugged in a box fan just to be sure. Is there a transfer switch somewhere that I'm overlooking?
polar bear is offline   Reply With Quote
Old 06-16-2014, 09:11 AM   #2
I guess I am learning something. I thought you had to be on generator or shore in order to get ac. I will have to read the manual.
2014 Solera 24R
David100 is offline   Reply With Quote
Old 06-16-2014, 09:29 AM   #3
My understanding is that is what the inverter does. It turns 12 volt DC from the batteries into 120 vac. I hope that if I'm incorrect someone will correct me. I was testing my batteries yesterday in preparation for a long trip (some of which will be spent "boondocking") and while using just my batteries my inverter was producing 120 vac......it just wasn't being distributed to any outlets.
Old 06-16-2014, 09:33 AM   #4
wmtire's Avatar
Yes, this is correct as to the function of an inverter......and yes you do have a transfer switch.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-16-2014, 10:24 AM   #5
Thanks for the help! Now to locate said transfer switch.
Old 06-17-2014, 06:58 PM   #6
ernest917's Avatar
I may be wrong but I don't think the inverter will power the AC.... It would suck the batteries in record time..... It will power a micro and a furnace and a few other things tho.....
ernest917 is offline   Reply With Quote
Old 06-18-2014, 05:48 AM   #7
You are correct the batteries aren't strong enough to power the air conditioner. What I was referring to was alternating current. The batteries produce 12 volt DC (direct current) and the inverter takes that and produces 120 vac. It is this 120 volt alternating current that powers the wall outlets, and this is my problem. I can verify the 12 volt DC going into the inverter and I can verify the 120 volt AC leaving the inverter but it's not reaching the outlets. The process of elimination leads me to believe that there is a disconnect or a transfer switch I haven't located.
Old 06-18-2014, 06:04 AM   #8
fonzie's Avatar
Your inverter might not supply any general 120 volts outlets. Most likely it will supply power to the TV and the residential fridge (if that's what you have).
Fonzie
Old 06-18-2014, 06:41 AM   #9
RSchleder's Avatar
Before you spend too much time trying to check your transfer switch, check to see if you have a GFI tripped. You will need to reset any tripped GFI in order to get the wall sockets to work. Also, don't forget to check them all as typically there's 2 or more in every RV. Good luck.
PS-fonzie has a good point, it all depends on how the coach is wired.
RSchleder is offline   Reply With Quote
Old 06-18-2014, 07:47 AM   #10
I did check all of the GFI's and they all seem to be in the reset position, but I never hurts to check again. I'm sure I'm overlooking something (probably something simple too) just not sure what it is. I will keep trying.......
inverter
