Old 06-28-2016, 01:26 PM   #1
Inverter replacement
I think I need to replace the inverter/converter under the passenger seat. The alarm continually goes off and the breaker is not off, have checked everything and cannot find the problem. Because it is not working our batteries won't charge. The plug on the front of the inverter is a GFI and it will not push in or reset so that's why I think the inverter has gone bad. Has anyone replaced this and if so, where did you get yours?
Sherol is offline   Reply With Quote
Old 06-28-2016, 03:56 PM   #2
grumpy0374's Avatar
Exactly what are you having problems with?
If your batteries are not charging, than that is your converter. Converter takes 115/120 volt and turns in into 12 volt, and charges batteries. Allows your 12 volt powered stuff and lights to work while plugged into shore power.
Inverter takes 12 volt and turns it into 115/120 volt to run things like ac and residential fridg. Won't charge batteries...uses battery up.
Grumpy
Steve & Cheryl + Charlie & Zoey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-29-2016, 08:35 AM   #3
The batteries are dead and will not charge. Alarm continually goes off. Lights are very dim even when plugged in. Have checked all breakers and fuses and they are OK.
Old 07-01-2016, 09:12 AM   #4
Well I purchased a new converter and installed it and that isn't the problem. Alarm still goes off continually. Now I guess I'll have to check out the batteries and connections. If that isn't it, it is back to the shop.
inverter, replacement
