Old 05-11-2013, 01:03 PM   #1
popbreed's Avatar
Magnadyne failed
Received our 2014 Lexi 300SS 2 weeks ago and now on our first camp out. Was listening to some music (FM) and was on the EQ screen to adjust for more bass. Turned up bass a little, heard a loud "burp" and then screen went blank. Unit will not turn on or "reset" Tried using 2 different sets of "U" tools to remove it from the dash so I can check the fuses on the back side and only one side releases. Ideas??
2014 Lexington GTS 300
2012 Jeep Liberty Toad
popbreed is offline   Reply With Quote
Old 05-13-2013, 07:35 AM   #2
GM
bclemens's Avatar
Do a search for U Tool. I remember a thread a while back where someone gave some tips on this. Where to stop/not go too far in.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-16-2013, 11:36 AM   #3
Displaced2's Avatar
One worked fine until 3200 miles. Now days away from home it has gone on its own vacation doing what. It wants when it wants.
Remember one thing. Reset button lower left corner.
Displaced2 is offline   Reply With Quote
Old 05-16-2013, 01:40 PM   #4
GM
bclemens's Avatar
Contact the Magnadyne factory direct and ask to speak to their technical sales specialist Mark Jones or Mike Thrush at 800 638-3600. There is an update out there.
Old 05-17-2013, 03:19 PM   #5
popbreed's Avatar
I am taking mine back to the dealer Tuesday AM to see if they can get the radio out of the dash. Maybe a fuse or maybe the radio is GONE!
Had another problem develop. The right rear fender flare has moved. Since the coach has full body paint, we now have a white line about 1/4" wide where the flare joins the sidewall along the back side of the flare. Does anyone know how the flare is attached to the sidewall The underside has been sprayed with heavy gray foam so any fasteners are hidden under the foam.
Old 06-17-2013, 04:21 PM   #6
popbreed's Avatar
update
It was a fuse but not the one on the back of the radio. The radio is supplied by a fuse in the panel on the side of the entry step. The fuse is noted as "accessory". Dealer replaced 15 amp with a 20 amp. He stated other items besides the radio are attached to it. Still cannot remove the radio from the dash and have now ordered a Sirius SXV100V so will try again.
Old 06-17-2013, 06:01 PM   #7
Displaced2's Avatar
Pick my unit up from dealer after upgrades and traveling this weekend. Will let you know if better. Talked to techs and very helpful. Need special tool supposedly supplies with Manuel to remove radio. Call and talk to guys.
Old 06-19-2013, 05:19 PM   #8
Displaced2's Avatar
Magnadyne seems to be working. Will know more as we will be traveling this weekend. The tool to remove the radio from the dash looks like a big sprung hairpin.
Old 06-19-2013, 05:55 PM   #9
hkreck's Avatar
Have you tried to remove the radio yet? When I went to remove my the first time I found after taking the dash apart that the radio was zip tied to the mounting bracket. Don't know if someone forgot to remove the zip tie or if someone did it for some other reason?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 06-19-2013, 06:17 PM   #10
Displaced2's Avatar
Dealer removed and upgraded. Left tool in dash pocket per my request
