Old 05-28-2013, 04:32 PM   #1
Displaced2's Avatar
Mattress
I have a 2013 Lexington 265GTS. My short queen mattress has rounded corners at top/bottom depending how installed.
If curves at bottom, plywood bases extends past mattress. If curves at head, have corner pockets and sheets lift off.
Did I get the wrong mattress?
Displaced2 is offline   Reply With Quote
Old 05-29-2013, 11:09 AM   #2
GM
bclemens's Avatar
No, we buy radiuses bottom corner mattress for walk around beds. I think the bases might have been slower to change over. Typically we put the curves at the top in that situation. No one ever uses the top corner...pillow normally covers that area. Fitted sheets should still work.
What I would do is put a chunk of foam at the top, put the radius at the bottom, extends the length of the bed.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-29-2013, 12:21 PM   #3
Displaced2's Avatar
You are so smart. That's why you get the BIG bucks.
