Old 08-30-2013, 07:07 PM   #1
RV Nomad
Need help removing roof sealant
My TV antenna shattered and I want to remove the three legs and replace the antenna. I have a 2005 Lexi 255GTS and I think the sealant used was Dicor. I've tried a putty knife but can barely dent the surface. Does anyone know how I can remove the sealant so I can get at the screws holding down the legs? When it's time to reseal, should I use Dicor or some other sealant. Thanks.
ID:	38934   Click image for larger version
olygene is offline   Reply With Quote
Old 08-30-2013, 07:35 PM   #2
Heat gun and a putty knife worked for me.
2012 Coachmen Freedom Express Deep Slide 270FLDS
2012 Ford F150 Eco Boost
Andersen WDH
uncle46 is offline   Reply With Quote
Old 08-31-2013, 08:12 PM   #3
Captain Capps
silica's Avatar
Send a message via Skype™ to silica
I just used a knife to slowly get under a portion of dicor then I was able to peal most of it in large chunks
silica is offline   Reply With Quote
Old 08-31-2013, 08:48 PM   #4
I would consider Eternabond when resealing.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
roo, roof
