Need to locate BiDirectional Isolator Relay Delay
Have looked all under and in 2010 255 GTS with no luck. The Isolator Relay is in a box just to the front of battery box. Also in that box are some fuses, etc. for slide outs and other things. But the BIRD is not there or anywhere around it or the battery box. It is not under the driver nor pass. seats. Not under dash on driver side or visible on pass. side. Not under the hood, either. Not under driver door panel that forms step just inside the sill. Does anyone know where it is or can anyone think of where I haven't looked?
Am working to attached diagram which came with the MH. The reason is my emergency start switch does not work even though switch checks good. I loose the GRN wire from the Isolator Relay when it disappears into some foam under the floor and there is no GRN wire connected to the switch.
The BIRD is working properly and the voltages on house and chassis are same after time delays. When I test it I hear the Isolator Relay click and the chassis voltage jumps up to same as coach. And when driving chassis charges coach.
Appreciate any help.
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
