Old 02-26-2014, 08:21 PM   #1
Onan 4KY generator
Anyone know where the white a/c output wire goes on the generator?
bill2004lex is offline   Reply With Quote
Old 02-26-2014, 08:53 PM   #2
TURBS's Avatar
Do you mean "where" does it go after it leaves the generator?
Need more info.
TURBS
Think spring!
The last man standing also has a sharpie
Old 02-26-2014, 09:55 PM   #3
VinceU's Avatar
Either an outllet for your shore power cord, if no outlet it will be connected to an auto-transfer switch in a compartment close by.
Old 02-26-2014, 09:59 PM   #4
VinceU's Avatar
Case I missed your question, the generator has a junction box on the side, all three output leads should be a single cable. Got a pic?
Old 02-26-2014, 10:38 PM   #5
The wires come from the RV thru a conduit and I know the black wire goes to the breaker, but the white wire has no connection point, unless it goes on the "ground" bolt!
Old 02-26-2014, 10:57 PM   #6
VinceU's Avatar
Can't "ground" common side, of A/C. Must lead to a common isolated bus. I suspect he is talking one of seven control leads from gen. They are all white per the drawings.
Old 02-27-2014, 01:43 AM   #7
This is the common wire which comes from the RV to the Generator and is one of the output voltage wires and the other wire is black and it connects to the small circuit breaker in the gen control!
Old 03-28-2014, 08:58 PM   #8
FLORIDA F.R.O.G.
RickLSmith53's Avatar
Speaking Of The Onan 4KW Generator
Speaking of the Onan generator... Don't forget to run it under load once per month. I just paid $530.00 to have the carburetor and associated parts replaced because I got lazy this winter. I won't make that mistake again! Ouch!!!
Rick Smith
RickLSmith53 is offline   Reply With Quote
Old 03-28-2014, 09:58 PM   #9
B and B's Avatar
Depending on how the unit is wired it is quite possible the Neutral and Ground are bonded in the actual genet based upon the model.
http://www.cumminsonan.com/www/pdf/m.../981-0530C.pdf
Brian
B and B
Old 03-31-2014, 03:42 PM   #10
I Re-installed my 4ky Onan Gen after repairing it, and finally hooked the white a/c wire on with other common wires on genset, everything works..Thanks to Everyone for Your help!
Old 03-31-2014, 03:47 PM   #11
Rick Smith
That is what happened to me and it took a while to fix it!
generator
